Export selected Archive data when Time Slider is enabled
590
09-23-2021 12:02 AM
Labels (3)
HiteshJilka
New Contributor III
Hello everyone,
RDBMS: Oracle 12.1.0.2
ArcMAP: 10.8
I have archiving enabled on Enterprise GDB feature class and can see historical data using time slider. I would like to export history data showing on map for a particular date on time slider. Although the data updated date is different, but the time slider displays the cumulative records. I want to export those changes visible on map.
I tried to select features from map, but in TOC, it shows extra records selected because Time Slider is hiding all other records. I tried export data for selected features and that exports all features and not based on what is shown on Time Slider.
Another thing I noticed on Attribute table is that selected records count is same as of current map (data visible from Time Slider). This is what I want to export so I tried to export from Attribute table option thinking that later I can link it with Archive data but ARCHIVE OBJECTID is not preserved.
Appreciate if anyone can help me to extract data based on time slider.
Thanks
HiteshJilka
New Contributor III
Update...
I didn't find a direct solution, but I did find a workaround to get the selected map data.
1. Select features when time slider enabled for a particular date
2. Run tool "Table to Excel".. This tool when creating excel file will preserves GDB_ARCHIVE_OID which is unique for each record.
3. Join created excel data with Archive layer using OID field.
