Change only the height of a feature
150
11-24-2021 03:01 AM
Labels (3)
IB3
Hi Community,
I have long and narrow polygon feature representing roads that I want to enlarge in height. I tried Scale in editor and of course its also enlarging the length.
The roads are connected to each other so I don't want to change this position. Just make the roads a bit larger.
Anyone has an idea how I could enlarge the height without adjusting manually the vertices?
Thanks!
JayantaPoddar
One way is to create another polygon (adjacent to your road polygon) with desired boundary using auto-complete polygon , and merge this polygon to your road polygon (Editor > Merge).
Another way is to select all the vertices at one side, and move.
Think Location
IB3
Thanks for sharing! You would have to select them one by one (or maybe with a rectangle) and that's what I wanted to avoid.
I will try with autocomplete!
KayHills
Thanks for sharing this.
