I have wanted tools in ArcMap that let me do more things with Standalone Tables. For example, there is no tool that will let me duplicate records in a Standalone Table or insert a row directly into an existing Standalone Table that came from the tabular portion of a feature. I cannot Copy/Paste rows or features into a Standalone Table at all like I can with features in a Feature Class. Even for features using Copy/Paste is slow and can only be done in an edit session. The Append tool works for table to table inserts or feature class to feature inserts, but only if the input and output are different from each other. The Append tool also will not let me take the tabular data of a feature and append it into an existing Standalone Table.
I wanted a tool that would quickly do inserts and work for Feature Class to Feature Class, Feature Class to Table, or Table to Table inserts. I also wanted the selection behavior to be similar to the Copy/Paste behavior. I wanted the tool to only work when records are first selected, and I wanted the selected records of the input to be cleared and the newly inserted records in the target to be selected when the tool finishes. That is especially useful when the input and the target are the same table or feature class. I also wanted the tool to automatically match fields like Copy and Paste does.
The field matching behavior is similar to using the default field map that appears in the Append tool when the NO TEST option is chosen, so the schemas don't have to match exactly. However, unlike the Append tool, the Insert Selected Features or Rows tool does not support multiple inputs and does not support customized field mapping.
An edit session should not be active if the data is versionsed, since arcpy cannot connect to an active edit session. The tool will internally start and stop an edit session when versioned data is involved. If data in not versioned an edit session may be active, but is not necessary. When an edit session is active for unversioned data, if the edit session is stopped before saving the inserts then the inserts will disappear without warning and will not be saved.
The tool lets you specify the number of copies of each feature or row you want to insert into the target layer or table view. The minimum number of copies is 1, and 1 is the default value.
NOTE: If the table view of the target is open when the tool is run, then the Append tool and my tool are affected by an Esri bug. The records are inserted, but the total record count of the table view does not update and the newly inserted records cannot be accessed or seen when Show all records view is active. However, since the inserted records are selected by my tool, after the tool completes the selected records count of the table view is updated and the new records do appear when the Show selected records view is active. To fully refresh the table view to show the new records in the Show all records view mode either the table view has to be closed and reopened or a field has to have its values sorted.
The attached python toolbox includes the code for the tool and the tool help files. I recommend that you save the attached toolbox in your "%APPDATA%\ESRI\Desktop10.2\ArcToolbox\My Toolboxes" directory. The toolbox also Includes my Multiple Field Key to Single Field Key tool for 10.2. For more on that tool see my blog here.
The code for the tool is shown below:
# Author: Richard Fairhurst
# Date: July 2015
import arcpy
class Toolbox(object):
def __init__(self):
"""Define the toolbox (the name of the toolbox is the name of the
.pyt file)."""
self.label = "Field Match Tools"
self.alias = ""
# List of tool classes associated with this toolbox
self.tools = [InsertSelectedFeaturesOrRows]
class InsertSelectedFeaturesOrRows(object):
def __init__(self):
"""Define the tool (tool name is the name of the class)."""
self.label = "Insert Selected Features or Rows"
self.description = ""
self.canRunInBackground = False
def getParameterInfo(self):
"""Define parameter definitions"""
# First parameter
param0 = arcpy.Parameter(
displayName="Source Layer or Table View",
name="source_layer_or_table_view",
datatype="GPTableView",
parameterType="Required",
direction="Input")
# Second parameter
param1 = arcpy.Parameter(
displayName="Target Layer or Table View",
name="target_layer_or_table_view",
direction="Input")
# Third parameter
param2 = arcpy.Parameter(
displayName="Number of Copies to Insert",
name="number_of_copies_to_insert",
datatype="GPLong",
direction="Input")
param2.value = 1
# Fourth parameter
param3 = arcpy.Parameter(
displayName="Derived Layer or Table View",
name="derived_table",
parameterType="Derived",
direction="Output")
param3.parameterDependencies = [param1.name]
param3.schema.clone = True
params = [param0, param1, param2, param3]
return params
def isLicensed(self):
"""Set whether tool is licensed to execute."""
return True
def updateParameters(self, parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
return
def updateMessages(self, parameters):
"""Modify the messages created by internal validation for each tool
parameter. This method is called after internal validation."""
if parameters[1].value:
insertFC = parameters[1].value
strInsertFC = str(insertFC)
if parameters[0].value and '<geoprocessing Layer object' in strInsertFC:
FC = parameters[0].value
strFC = str(FC)
if not '<geoprocessing Layer object' in strFC:
print("Input FC must be a layer if output is a layer")
parameters[0].setErrorMessage("Input must be a feature layer if the Output is a feature layer!")
else:
dscFCLyr = arcpy.Describe(FC)
dscinsertFCLyr = arcpy.Describe(insertFC)
# add the SHAPE@ field if the shapetypes match
if dscFCLyr.featureclass.shapetype != dscinsertFCLyr.featureclass.shapetype:
print("Input and Output have different geometry types! Geometry must match!")
parameters[0].setErrorMessage("Input and Output do not have the same geometry")
if dscFCLyr.featureclass.spatialReference.name != dscinsertFCLyr.featureclass.spatialReference.name:
print("Input and Output have different Spatial References! Spatial References must match!")
parameters[0].setErrorMessage("Input and Output do not have the same Spatial References! Spatial References must match!")
if parameters[2].value <= 0:
parameters[2].setErrorMessage("The Number of Row Copies must be 1 or greater")
return
def execute(self, parameters, messages):
"""The source code of the tool."""
try:
mxd = arcpy.mapping.MapDocument(r"CURRENT")
df = arcpy.mapping.ListDataFrames(mxd)[0]
strFC = str(FC)
FCLyr = None
insertFCLyr = None
for lyr in arcpy.mapping.ListLayers(mxd, "", df):
# Try to match to Layer
if '<geoprocessing Layer object' in strFC:
if lyr.name.upper() == FC.name.upper():
FCLyr = lyr
if '<geoprocessing Layer object' in strInsertFC:
if lyr.name.upper() == insertFC.name.upper():
insertFCLyr = lyr
if FCLyr == None or insertFCLyr == None:
# Try to match to table if no layer found
if FCLyr == None:
tables = arcpy.mapping.ListTableViews(mxd, "", df)
for table in tables:
if table.name.upper() == strFC.upper():
FCLyr = table
break
if insertFCLyr == None:
if table.name.upper() == strInsertFC.upper():
insertFCLyr = table
break
# If both layers/tables are found then process fields and insert cursor
if FCLyr != None and insertFCLyr != None:
dsc = arcpy.Describe(FCLyr)
selection_set = dsc.FIDSet
# only process layers/tables if there is a selection in the FCLyr
if len(selection_set) > 0:
print("{} has {} {}{} selected".format(FCLyr.name, len(selection_set.split(';')), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's'))
arcpy.AddMessage("{} has {} {}{} selected".format(FCLyr.name, len(selection_set.split(';')), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's'))
FCfields = arcpy.ListFields(FCLyr)
insertFCfields = arcpy.ListFields(insertFCLyr)
# Create a field list of fields you want to manipulate and not just copy
# All of these fields must be in the insertFC
manualFields = []
matchedFields = []
for manualField in manualFields:
matchedFields.append(manualField.upper())
for FCfield in FCfields:
for insertFCfield in insertFCfields:
if (FCfield.name.upper() == insertFCfield.name.upper() and
FCfield.type == insertFCfield.type and
FCfield.type <> 'Geometry' and
insertFCfield.editable == True and
not (FCfield.name.upper() in matchedFields)):
matchedFields.append(FCfield.name)
break
elif (FCfield.type == 'Geometry' and
FCfield.type == insertFCfield.type):
matchedFields.append("SHAPE@")
break
elif insertFCfield.type == "OID":
oid_name = insertFCfield.name
if len(matchedFields) > 0:
# Print the matched fields list
print("The matched fields are: {}".format(matchedFields))
arcpy.AddMessage("The matched fields are: {}".format(matchedFields))
copies = parameters[2].value
print("Making {} {} of each {}".format(copies, 'copy' if copies == 1 else 'copies', 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row'))
arcpy.AddMessage("Making {} {} of each {}".format(copies, 'copy' if copies == 1 else 'copies', 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row'))
oid_list = []
# arcpy.AddMessage(oid_name)
dscInsert = arcpy.Describe(insertFCLyr)
oid_name = arcpy.AddFieldDelimiters(dscInsert.dataElement, oid_name)
else:
oid_name = arcpy.AddFieldDelimiters(dscInsert, oid_name)
rowInserter = arcpy.da.InsertCursor(insertFCLyr, matchedFields)
print("The output workspace is {}".format(insertFCLyr.workspacePath))
arcpy.AddMessage("The output workspace is {}".format(insertFCLyr.workspacePath))
versioned = dscInsert.featureclass.isVersioned
else:
versioned = dscInsert.table.isVersioned
if versioned:
print("The output workspace is versioned")
arcpy.AddMessage("The output workspace is versioned")
with arcpy.da.Editor(insertFCLyr.workspacePath) as edit:
with arcpy.da.SearchCursor(FCLyr, matchedFields) as rows:
for row in rows:
for i in range(copies):
oid_list.append(rowInserter.insertRow(row))
else:
print("The output workspace is not versioned")
arcpy.AddMessage("The output workspace is not versioned")
for row in rows:
del row
del rows
del rowInserter
if len(oid_list) == 1:
whereclause = oid_name + ' = ' + str(oid_list[0])
elif len(oid_list) > 1:
whereclause = oid_name + ' IN (' + ','.join(map(str, oid_list)) + ')'
if len(oid_list) > 0:
# arcpy.AddMessage(whereclause)
# Switch feature selection
arcpy.SelectLayerByAttribute_management(FCLyr, "CLEAR_SELECTION", "")
arcpy.SelectLayerByAttribute_management(insertFCLyr, "NEW_SELECTION", whereclause)
print("Successfully inserted {} {}{} into {}".format(len(oid_list), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's', insertFCLyr.name))
arcpy.AddMessage("Successfully inserted {} {}{} into {}".format(len(oid_list), 'feature' if '<geoprocessing Layer object' in strInsertFC else 'table row', '' if len(selection_set.split(';')) == 1 else 's', insertFCLyr.name))
else:
print("Input and Output have no matching fields")
arcpy.AddMessage("Input and Output have no matching fields")
else:
print("There are no features selected")
arcpy.AddMessage("There are no features selected")
# report if a layer/table cannot be found
if FCLyr == None:
print("There is no layer or table named '{}' in the map".format(FC))
arcpy.AddMessage("There is no layer or table named '" + FC + "'")
print("There is no layer or table named '{}' in the map".format(insertFC))
arcpy.AddMessage("There is no layer or table named '{}' in the map".format(insertFC))
arcpy.RefreshActiveView()
return
except Exception as e:
# If an error occurred, print line number and error message
import traceback, sys
tb = sys.exc_info()[2]
print("Line %i" % tb.tb_lineno)
arcpy.AddMessage("Line %i" % tb.tb_lineno)
print(e.message)
arcpy.AddMessage(e.message)
Field Match Tools v10.2.zip
