Bulk Create Assignments
118
8
09-27-2022 08:28 AM
DominickBernstein2
Hello
I added in a filtered layer into my dispatcher map. I am trying to select all of these features and create assignments for them. It seems like Workforce is limiting me to select and create a max 10 assignments at once. Is there a limit on bulk assignment creation? I really need to be able to create more then 10 assignments at a time, I am trying to assign out a lots of jobs in a large service area.
CraigGillgrass
Yes, I believe it's in Enterprise 11 - we don't back port new functionality so you'd need to upgrade for that UX.
CraigGillgrass
@DominickBernstein2 are you using Online or Enterprise?
Craig
DominickBernstein2
Enterprise
CraigGillgrass
What version of Enterprise?  We have changed this behavior but only in recent releases of Enterpirse.
DominickBernstein2
10.81
CraigGillgrass
The enhancement we made for this isn't in 10.8.1; it will be in the Enterprise 11 release.
Craig
DominickBernstein2
Got it so we will have to upgrade to 11 to be able to bulk assign assignments?
CraigGillgrass
IanGallo
If you have all relevant data needed to create assignments stored outside of workforce you can just append to the Assignments table in Pro from a csv. This is how I bulk add assignments (a few thousand at a go). The schema outline in this article is helpful in doing that. Automation and Scripting with ArcGIS Workforce—ArcGIS Workforce | Documentation
