ArcGIS Workflow Manager Blog
81
12.4K
25
Open | Defining a start and end date for a step would be something really helpful. Capability of setting a start and end da... by PabloRebufello New Contributor III 4 2 | 4 | 2 | |
Open | Hi,Requirement is to open map in ArcGIS Pro.We have 20 different maps and to open maps we have to create 20 different... by sirishb New Contributor III 0 0 | 0 | 0 | |
Closed | I realize this may come across as pedantry but I think names are important. According to the help, "Workflow items ar... by philippenn Occasional Contributor 0 2 | 0 | 2 | |
Implemented | Option to duplicate existing Saved Searches will be very much helpful. by Ranga_Tolapi Occasional Contributor III 0 8 | 0 | 8 | |
Under Consideration | Can you please add a 'Delete job' as a step type in Workflow Manager. This seems like it should be an option but it i... by JessePearson New Contributor III 0 4 | 0 | 4 | |
Open | In Workflow Manager Classic it would be good if there was no requirement to edit an extended property when running an... by MJames New Contributor III 0 0 | 0 | 0 | |
In Product Plan | It should be possible to add multiple related properties entries at a time using the edit extended properties step in... by MJames New Contributor III 0 1 | 0 | 1 | |
Already Offered | When using the ‘JTXDesktopSteps.LaunchArcMap‘ step type in ArcGIS Pro the only way to save any edits done to the open... by JHart New Contributor II 1 2 | 1 | 2 | |
Implemented | Please, add an option to modify, edit, add, delete the default three JOB PRIORITY from LOW, MEDIUM and HIGH to user d... by MilkoVelichkov New Contributor III 1 10 | 1 | 10 | |
In Product Plan | It just makes natural sense that Workflow Manager should be able to send out webhooks for integration into other syst... by COSPNWGuy Occasional Contributor II 5 7 | 5 | 7 |
Idea Submission Guidelines
