In Workflow Manager Classic it would be good if there was no requirement to edit an extended property when running an edit extended property step in order for the step to progress. Currently we use the edit extended property step to make the user check information that has been entered into a job. Often the information is correct and does not have to be edited however the only way for the step to progress is to click 'Cancel' as the 'Ok' button is greyed out until a property is updated. This process is counter intuitive to our users as clicking 'Cancel' makes them believe they are cancelling the step, not accepting that no changes are required. I think a nice solution would be to not have 'Ok' greyed out but to instead have the step provide different return codes depending if a property was edited or not.
