Web AppBuilder Filter and Summary Tools Question
182
12-01-2023 12:44 PM
ChadLeftwich
I'm working within ArcGIS Web AppBuilder, in particular trying to use the Summary widget in conjunction with the Filter widget. The Summary widget by default shows all sums, counts, etc. within a specified layer, but I want to set up the filter tool to default, when activated, to turn off certain entries.
Essentially, the user will tap the filter widget, which has a filter that automatically activates when the widget is chosen, and then they will see the readout of the remaining values in the Summary tool.
Is this possible or does the filter tool not persist once closed, thus causing the summary tool to not represent the desired filter?
