Switch the query layer base on the URL parameter ?
211
10-20-2021 01:06 PM
LeLuong
New Contributor III
All.
Is there a way I could use the URL parameter (ex: year ) to tell filter widget to pick the right layer to do the filter on ?  Is it even possible ?  Thank you.
ABishop
Is there a reason you need to us a URL parameter?  You can set the filter widget to use expressions determined by the user.
Amanda Bishop, GISP
LeLuong
New Contributor III
The idea is to have it automated as much as possible for users.  Users will open the app from a hyperlink in other app.  When my app opens it's zoomed to the selected polygon (through URL parameter) .  Now having multiple years to the app makes it tricky.  Thanks.
vtey_esriau
New Contributor II
Not possible OOTB afaik. Will need custom coding
LeLuong
New Contributor III
Thanks @vtey_esriau .
