Showing 2D map using 4.x API in WAB
85
12-07-2021 10:37 PM
Qusai_Kanani
Hello
Is there an equivalent for createMap() function from "esri/arcgis/utils" in ArcGIS API for JavaScript 4.x ?
I am seeking to use 4.x JS API to build a Web AppBuilder application with a 2D map, is that doable in Web AppBuilder?
jcarlson
MVP Frequent Contributor
According to the WAB documentation:
Supported versions of ArcGIS API for JavaScript
2D apps support ArcGIS API for JavaScript 3.38, and 3D apps use ArcGIS API for JavaScript 4.21. See the API system requirements for additional information.
I think you're out of luck here. Experience Builder is pretty nice, though, if you don't need some of WAB's more niche widgets.
- Josh Carlson
Kendall County GIS
LibingWang
Is it possible to get a base map asynchronously by 4.21 API like  createMap() do in 3.x? Thank you!
