Problem with csv file export
187
10-25-2021 06:22 AM
Jcordovafredes
Hi, do you know why you can't export the files in csv from the table in attributes in appbuilder?
JayantaPoddar
MVP Esteemed Contributor
You need to enable the option to allow exporting attribute tables to CSV files from (Configure) Attribute Table Widget. Here is how you could do it.
Attribute Table widget—ArcGIS Web AppBuilder | Documentation
Think Location
Jcordovafredes
Hello, @JayantaPoddar  thanks for the answers, I forgot to indicate the following: the export to csv option is enabled.
When I edit the appbuilder I can export the file without any problem, the problem is that when I publish and launch the application to the "final" view, I cannot see this:
JayantaPoddar
In the setting of your browser  > Downloads, enable "Ask me what to do with each download" (screenshot for Edge)
Think Location
Jcordovafredes
No either, because the option when I edit the options in appbuilder allows me to download without any problem, not when I publish it
Jcordovafredes
There is a problem for the export of csv, but the problem does not lie in appbuilder but for some reason that I do not know. Experience builder blocks it, do you know what that could be due to?
