District Lookup widget results popup not updating
72
09-29-2022 11:49 AM
PLadd
Occasional Contributor II
I am using the District Lookup widget in WAB.  The WAB references a web map which includes the layers that are published using AGPro.  In AGPro I am configuring the popup, saving, and publishing from here.  When I ID a feature in the web map, the popup shows same as AGPro configuration.  But the District Lookup results do not get updated.  The only solution is to delete the District Lookup widget from my WAB, add it, and reconfigure the settings.  Only then do the changes made from AGPro display in the WAB app.
Does anybody know of a more efficient way to update the results of the District Lookup widget?
PLadd
One more thing to add: I have confirmed it's not a cache issue.  Nor is it a Google Chrome issue.
