Context: When exporting a point dataset to csv using WAB's attribute table, AGO appends an x and y field and populates with coordinates based on the data's spatial reference. There is no option to configure the output units for x and y. The default seems to be web merc coordinates in meters. We'd like to be able to configure the widget to export the x y coordinates in decimal degrees, a format that our audience can use without needing to do a translation.
