Integrate ArcGIS Velocity into an Azure first workflow?
414
11-20-2020 01:25 AM
GEOINT_ENGINEER
Many of our customers are using an Azure serverless infrastructure. Do you have any documentation regarding best practices integrating ArcGIS Velocity into Azure Data Factory ?
PeterNasuti
Hi @GEOINT_ENGINEER thanks for your post and apologies for the delay in reply.
For integration with Azure, ArcGIS Velocity offers the following feed and source types among others that can be used in various workflows to ingest data from Azure or write data to Azure that can be leveraged by Azure Data Factory services:
Feed types:
Azure Event Hub
https://doc.arcgis.com/en/iot/ingest/azure-event-hub.htm
Azure Service Bus
https://doc.arcgis.com/en/iot/ingest/azure-service-bus.htm
Source types:
Azure Blob Storage
https://doc.arcgis.com/en/iot/ingest/azure-blob-storage.htm
Azure Cosmos DB
https://doc.arcgis.com/en/iot/ingest/azure-cosmos-db.htm
Additionally, ArcGIS Velocity supports the following Azure outputs among others:
Azure Blob Store
https://doc.arcgis.com/en/iot/disseminate-and-notify/azure-blob-store.htm
Azure IoT Hub
https://doc.arcgis.com/en/iot/disseminate-and-notify/azure-iot-hub.htm
PeterNasuti
Feed types:
Azure Event Hub
Azure Service Bus
Source types:
Azure Blob Storage
Azure Cosmos DB
Azure Blob Store
Azure IoT Hub
