UNtools for 2.9
176
5
11-30-2021 10:54 AM
TedCronin
MVP Honored Contributor
Will there be a UNtools for Pro 2.9?  I see 2.8.2 from inside of Pro and Add Packages.  What is the process to get the 2.9 from Conda\Esri repository?  (Untools :: Anaconda.org)
TedCronin
After a refresh the 2.8.2 disappears as well.
MikeMillerGIS
They were shared on anaconda 18 days ago.  If they are not visible in the python backstage, try installing them through the python command prompt.
Click Start - Python Command Prompt
Type the following "conda install -c esri untools"
This should install the 2.9.0 version.
Albus68
Correct!
Thanks @MikeMillerGIS
RobertThomson
Occasional Contributor II
DanPatterson
or to have a look-see at what else will happen during an install, here is the conda route... --dry-run is always a good idea at first, remove it if you are satisfied
... sort of retired...
