Unable to rename during apply asset package
188
11-17-2021 12:06 AM
PierreloupDucroix
I am trying to apply the Electric Asset Package from the Electric Data Management for ArcGIS Enterprise.
Every time I try to use the D_rename table to translate to non-English language, it fails with error :
ERROR 002123: No summary attributes were found matching input network attribute type.
Failed to execute (SetSubnetworkDefinition).
What I have done so far :
- upgrade Asset Package to the proper version (untools version 2.9.0, but it was the same with 2.8.2) -> OK
- Stage utility Network in a file geodatabase or a mobile geodatabase -> OK
- Apply Asset Package with several tests:
-- rename using French, also tried with German, Chinese --> Error
-- add another field to D_rename and copy the values of field "current name" (in English) -> OK
-- truncate French values to =< 32 characters -> Error
-- Remove all special characters (ie. é,â,', etc...) -> Error
A bug (https://support.esri.com/fr/bugs/nimbus/QlVHLTAwMDE0MzYyMg==) was referencing this specific error, but it has now change and says it is due to value length.
Has anyone succeeded in using this functionality ?
Regards
PaulLeBlanc1
There is also a second bug in untools.
Here is a RC you can test with https://anaconda.org/solutionsdev/untools/files
  1. Open a python command prompt
  2. conda install -c solutionsdev/label/pro2.9 untools
untools 2.9.1 is tentatively scheduled for a public release in December.
MikeMillerGIS
Attached is an updated rename table with length issues resolved.  We have identified a bug with terminal configuration and working on a fix.  I will post here when a fix is available.
PierreloupDucroix
Thank you, Mike,
After removing the D_rename table from my asset package et copying the new one, it still fails with the same error.
I tried both a file geodatabase (.gdb) et a mobile (.geodatabase)
What was the workaround in your D_rename table ?
Below is the log file:
Apply Asset Package
Parameters
Asset Package D:\UN\Databases\Electric_AssetPackage_v29.gdb
Domain Networks to apply Structure;Electric
Input Utility Network D:\UN\AP_load_fr.gdb\fd\un
Load data INCLUDE_DATA
Calculate Spatial Index and Analyze ANALYZE
Output Utility Network
Configurations to apply 'Transmission Tier';'SubTransmission Tier';'Distribution Tier';'Unbalanced Polyphase';'Metric Unit Attributes'
Rename using French
Post Process NO_POST_PROCESS
Messages
Start Time: jeudi 18 novembre 2021 08:48:11
ArcGIS Pro 2.9.32739
untools 2.9.0
Executing from ArcGIS Pro, 0 map(s), activeMap = False
Parallel processing enabled: 3
Asset Package schema version: 2.9
Staging directory -- D:\UN\Databases\AP_Workspace31
Failed to execute. Parameters are not valid.
Failed to execute (AssetPackageToUtilityNetwork).
Failed at jeudi 18 novembre 2021 08:59:51 (Elapsed Time: 11 minutes 39 seconds)
PaulLeBlanc1
PierreloupDucroix
Hi Paul,
It works with the 2.9.0.3 RC
Thank you very much
