Field Maps tracing error
188
3 weeks ago
gis_KIWI4
Occasional Contributor II
Has anyone encountered this?
is there a setting I can change to get this to work?
it works when I select shorter “trace routes” which I assume select a lesser features than the case above.
UN version 6
Enterprise 11.1
Thanks, any help is appreciated:)
PierreloupDucroix
Hello, have you tried to increase the maximum number of records returned by the server in your UN service ?
https://enterprise.arcgis.com/en/sites/latest/content/server-configuration-details.htm
Or better --> you should modify your named trace in order to return less features, so that it is usable in field maps
