Good morning,
I try to count all adresses (in my Device Layer) with a specific attribute (MainProvider). For that, i tried the following code (as mentioned here: UN Attribute Rules Expression Builder Arcade😞
// load all addresses var addresses = FeatureSetByName($datastore, "AddressTableName", ["MainProvider"], false) // filter the addresses for the main provider of the active feature var provider = $feature.MainProvider var filtered_addresses = Filter(addresses, "MainProvider = @provider") // count and return error message if(Count(filtered_addresses) > 25) { return {"errorMessage": "A provider can't supply more than 25 addresses!"} } // if we land here, the provider has <= 25 addresses // rest of your code
When I use this code, the value of "filtered_adresses" is always identical with the amount of features in my device layer. So I guess the Filter is not working like this.
Do you know what I can do here? Or is there another way to get this done? Thanks in advance!
Luca
