Hi all,
I have a bunch of points that I would like to turn them into Subnetwork controllers, normally to modify the Subnetwork controller you have to manually input the information. For my case I have thousands of node to enable Subnetwork controller, I am not familiar with programming but I was wondering if there are any ways to write a python code that allows me to batch enable subnetwork controller.
The easiest and safest way to accomplish this is to create a CSV file with all the required information to create the controllers and use the Import Associations tool. If you follow the provided link to the online help which columns are required and how to run the tool.
