syntax to use multiple join() functions in one calculation cell
141
4 weeks ago
WilliamSteinley
I'm trying to use join multiple times in once calculation cell. using the code below applies a math formula to it. what syntax should i use?
join("\n", ${tree_number}, "|") + join("\n", ${dbh}) + join("\n", ${height}, '|')
abureaux
MVP Regular Contributor
That's not how join() works. See Formulas.
join(separator, question)
Concatenates all answers to a given question in a repeat, separated by the given separator.
join(',', ${question_in_repeat})
You should have three separate calculates for those three joins. Then, use concat() to combine all of the joins and plain text. General example:
concat("\n", ${join_tree_num}, "|", "\n", ${join_dbh}, "\n", ${join_height}, "|")
Also, don't mix quotes. Use either single or double.
