Survey123 geoshape extent
364
09-30-2022 04:57 AM
JamesRichardson_SK
I am currently trying to edit my geoshape question so that once collected, the view (current view below) has a greater extent (is not as tightly zoomed in), is there a way to achieve this?
Tags (3)
ZacharySutherby
Hello @JamesRichardson_SK
If you authored your survey in Connect on the Map tab you can set the extent of the Preview map to be zoomed out.
Thank you,
Zach
JamesRichardson_SK
Hi Zach,
That doesn't seem to change the viewing extent, eventually that view will be part of a feature report and I would like the extracted image to provide a view of a greater extent for context in the report.
Thank you,
James
