Survey123 Form
76
Thursday
HamzahIsmail
Currently building a survey form using Survey123 connect version 3.16.106.0 and have noticed the following.
Question 1: Does the floor have any toilets?
Answer options are "Yes" or "No"
If "yes" is selected, automatically 4 more questions appear in the survey form. Namely to count the number of male, female, disable, and unisex toilets.
I have added the correct input into the Relevant field in the xls forms and it hides the 4 related fields of Questions 1, but it leaves a blank space in the form. Form style is set to 'pages fixed-grid'
The view carries over into the mobile app. It is taking unnecessary space and should ideally only appear when "yes" is selected.
Please assist me
MuhammadSameem
You can put selected formula in all the relevant fields to match and display it with condition like this : selected(${toilet_choice}, 'yes')
HamzahIsmail
Thanks Muhammed. This is the condition in the relevant field. While the 4 related choices are not apparent when yes is not selected, the space is still occupied. Previously the space would be reduced.
