Sorting and distinct values using search function in Survey123
792
9
08-05-2021 06:55 AM
vijaybadugu
I need to Sort and get Unique values using CSV or Feature service with search function. Could you please tell us what to do ?
Philip-Wilson
Esri Frequent Contributor
Hi @vijaybadugu,
You can find the documentation about Linked Content here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformessentials.htm#ESRI_SECTION1_34A4D....
You can link a CSV from AGO/Enterprise, and the app will download the CSV to the media folder, to use just like any other CSV you put in media folder. This will work offline as normal. When the CSV gets updated online in AGO/Enterprise, the next time the user goes into the survey (on the info page) the CSV will be automatically downloaded and updated in the media folder.
Regards,
Phil.
Philip-Wilson
Hi @vijaybadugu,
Could you please provide more details and usage of the search() function, areyou using in 3.12 release or 3.13 beta? Currently search() is only a beta feature.
Also can you provide your xslx file and media files (csv) and details on what you are trying to achieve?
Regards,
Phil.
vijaybadugu
I was using 3.12 .
vijaybadugu
I uploaded the Media File. I included feature service access using search() function .  i have a requirement that, if the device is offline , it automatically pulls the data from local media csv file . if the device is online, it pulls the data from actual service data. few people suggested that, use "Linked content with CSV" and update the CSV content regular periods . How this works and is it possible to update local copy of csv file using Python API ? Will fieldworker get any notification that, your Linked content CSV updated please try to download latest copy of it? I did not find much documentation on it.
vijaybadugu
When I try to access from CSV file, I Could not able to get Unique values  for this I have to create separate column with Unique values. there is no specific function sorting in search() function to sort the list.
Philip-Wilson
Hi @vijaybadugu,
Regards,
Phil.
vijaybadugu
Thanks for your clarification . How to update csv content in Arcgis online / enterprise using python with windows scheduler ?
vijaybadugu
Thanks for info. I am able to update the content in ArcGIS enterprise with ArcGIS API for Python. My Last Question is , I think you have seen the CSV with Duplicate IDS in it. How to Get Unique , sort items to load in to dropdown using search() ?
Philip-Wilson
Hi @vijaybadugu,
The search function() and also pulldata() are designed to only return one unique value, the first value they find, therefore the list order and unique values need to exist in your datasource so that the CSV reflects this.
Regards,
Phil.
vijaybadugu
