Search appearance bug when editing existing record in web form
137
04-12-2024 07:13 AM
AnthonyJonesRSK
Occasional Contributor II
I was hoping someone could assist as I think I have stumbled across a bug with the search appearance when using url parameters in the web form. When attempting to edit an existing record in my survey, if I simply want to edit the record everything works fine.
So https://survey123.arcgis.com/share/32d28c25ee9e4a0b9599bf1430162843?mode=edit&globalId=aceb084d-e547-4600-8a5e-9fc7ecedcb47  allows me to edit the record and the select_one with the search appearance (the Project Number question) works as expected, see below.
If however, I want to update a field in my survey using the &field: url parameter I find that the select one with the search appearance will not pull through the existing data.
So the url https://survey123.arcgis.com/share/32d28c25ee9e4a0b9599bf1430162843?mode=edit&globalId=aceb084d-e547-4600-8a5e-9fc7ecedcb47&field:example2=no where I want to update the Example select_one question to "no" causes the Project Number question to fail to pull through the existing record, see image below. To be clear this happens whenever I use the field parameter to try and update any other field.
I've tried this with two surveys now and get the same result. I also searched online for this but couldn't see that anyone else had highlighted this problem. If someone could assist with this it would be much appreciated.
Anthony
