S123 Error occurred while generating report
141
6
09-20-2021 11:55 AM
wilcow
Generating a report (pdf and docx) gives me this error on the Data page for a survey we've been using for over a year:
An error occurred when checking the report template. Failed to parse ${ds1_image1 | size:460:0} since size is not supported for the current field.
this report has a ton of photos and this isn't even the first image in the list so I'm confused - why would the 1st 3 image fields be OK, but not this one?
ZhifangWang
Hi @wilcow ,
Thanks for sharing the XLSForm and report template files, these help us locate the cause of the issue.
It turns out that in your XLSForm, there are several image questions (~21 rows) are set bind::esri:fieldType=esriFieldTypeString by mistake. This is caught by the syntax checking enhancement in the latest release last week.
After fixing all bind::esri:fieldType errors in the XLSForm and republish your survey, the report should be able to print as expected.
Please let us know if you still observe any issues after the change.
Zhifang
JamesTedrick
Esri Esteemed Contributor
Hi @wilcow ,
The error message did not come through in the post - can you please re-share?  Just to confirm, the only use of "ds1_image1" is as an image question in the form?
Have you opened an Esri Support case to look into this?  Can you share the form and template designs?
wilcow
here's the error again
to confirm, yes, that's the only use of "ds1_image1"
wilcow
attaching the template and form as well
wilcow
@JamesTedrick
I have not created a support ticket - hoping it's something I can address internally
ZhifangWang
Hi @wilcow ,
Zhifang
wilcow
thanks @ZhifangWang and @JamesTedrick for the assist - fixed the mapping for those image fields and republished and the report downloads error-free
