S123 Connect Performance is Poor
1020
13
03-29-2023 02:48 PM
LydiaWerner_MAC
Has anyone had issues with the performance in S123 Connect being poor? I have experienced it taking a considerable amount for the app to launch, the app crashing while in a survey form, or running other routine tasks. I have a fairly high performance desktop, so all the culprits such as RAM, CPU, etc., aren't indicating an issue.
TIA!
ChristopherCounsell
MVP Regular Contributor
I'd always recommend specifying the version, it really does help.
I the end we can offer a few suggestions:
  •  Survey123 Connect version (apparently not)
  • Survey forms (does not sound like it)
  • Broader issues (none appear to be reported by other users)
  • PC (you have ruled out, and the app itself is light)
The last two things you can investigate are tied to network traffic:
  • Where is the Survey123 Connect content directory? Is it your local drive or have you tried to place it on a network? Is it on a OneDrive or something?
  • What is your internet/network environment like? Is Survey123 Connect slow if you connect to a different WiFi? Do you have antivirus running? Is your IT security tight?
rsun_TQB
Hi @LydiaWerner_MAC ,
Yes, but not all surveys will have poor performance on Survey123 Connect. We add the 4000ish addresses for one of text field for autocomplete purpose. It sometime was extremely slow when save and try to sync back to the Portal.
Regards
ChristopherCounsell
This is most common with two things:
  • Surveys with a lot of calculations
  • Surveys with big lists. At some point (500 per list) you really want to move to external choice lists.
As @rsun_TQB mentioned 4000 choices = slow. They'll be created as domains. Better to push to a csv. See more on working with large lists here:
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-external-choice/ba...
LydiaWerner_MAC
@rsun_TQB & @ChristopherCounsell , I'm well aware of performance issues when you have large lists, etc. These are not  contributing factors at all for my surveys. As I said previously, the app takes forever to load, in addition to crashing at random times.
rsun_TQB
I would suggest contacting Esri support, and your IT department at the same time.
If it's a global issue of Survey123 Connect being slow, Esri will treat it as high priority to fix this issue...but if it is not caused by the reason both @ChristopherCounsell and I talked about. It might be something going on with your Mac or PC or even network issues regarding VPN or internet speed.
Hope the issue that you are facing will be resolved soon 🙂
DougBrowning
Are you on the latest version?  My Connect loads in 3-4 seconds.  I have forms 500+ lines and 10,000+ in the lists without issue.  It can be a clunky app at times but nothing major.  I get a few crashes a year maybe.  Are you installing it in a place besides C or anything like that?
LydiaWerner_MAC
I'm running the most recent version, so that's not the issue. I can try installing it elsewhere, thanks for that idea.
ChristopherCounsell
What version of Survey123 Connect?
Is your internet stable? Anything going to stop the app communicating? Survey123 Connect leverages the survey123.com API.
LydiaWerner_MAC
I'm running the most recent version, so that's not the issue. Thanks.
ChristopherCounsell
