Return label answer from select_mult as a note in Repeat Group
70
06-30-2022 10:17 AM
LouryMello
Hello,
I did a survey form with a Repeat Group relevant from select_mult question. The number of repeats depends how many options are selected. And I wish show a selected answer as a note on the begining of repeat. When I tried it with selected-at(${cultivo_mult}, position(..)-1), it bring me out the name of choice and I want to show the name of the label.
After, I tried  jr:choice-name(${cultivo_mult}, '${cultivo_mult}') but when I selected more than one option and change to next repeat the name of the note dind't change as a error.
I am not sure if a explain nice.
I am leaving the .xslx
2 Solutions
DougBrowning
MVP Notable Contributor
Did you try this? You have the correct 2 parts you just need to combine them.
 jr:choice-name(selected-at(${cultivo_mult}, position(..)-1), '${cultivo_mult}')
It shows an example that is close in the help here  https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
Hope that helps
lourymello1
New Contributor II
Thank you, Doug!!
That works!!
DougBrowning
Hope that helps
lourymello1
New Contributor II
Thank you, Doug!!
That works!!
