"Something broke the parser" - error publishing!
490
07-30-2021 01:31 PM
JCOSNatRes1
Hello!
I am experiencing an "Error converting XLSForm" issue. Error contains the language:  ODK Validate Error "Something broke the parser" when trying to publish my survey.
I've looked over previous comments with similar errors and am pretty sure that I:
     1) am not relying on any "relevant" statements in the survey, so shouldn't be getting hung up there,
     2) I believe none of my field names are too long or improperly formatted
Any help would be appreciated!  Still new at this.  Spreadsheet attached.
Ruth_JiatengXu
Hi @JCOSNatRes1
Thanks for sharing here! It seems like there is a comma missed in your concat() calculation.
Ruth
Ruth_JiatengXu
Hi @JCOSNatRes1
Ruth
BotanyJCOSNatRes3
Incredible.  Thank you so much, Ruth!  That was absolutely the problem.  I greatly appreciate your help!!
- Jesse
Arnaud_Brival
Hi @Ruth_JiatengXu
Appologies but I'm suddenly experiencing a similar issues. The XLS form worked like a brease before but I must have inserted a mistake somewhere but I'm absolutely unable to find it.  I was also unable to decifer (nor copy and paste) the error message given by Survey123.
If you have a tool to test or find out more about the error, Would you accept to have a look at this rather complicated Xlsform?
Ruth_JiatengXu
Hi @Arnaud_Brival
Thanks for sharing here, and I am sorry for the late response.
It seems like there is an extra "`" in the choice_filter column for your Operator_lzin question, see the screenshot below:
I have attached the XLSForm with the extra "`" removed, and this should work with no issue.
Ruth
