Pull data from csv doesn't work when I save it in a newer version
149
12-04-2023 07:38 AM
Giota_Zach
Hello, I created a survey123 form a year ago that pulls data from a csv file. I'm currently looking to update the CSV file.  However, I've encountered an issue where the search functionality stops working as soon as I save the file, regardless of whether I make changes or not.
Any clue why this happens?
Without doing any changes csv last saved 09/2022:
After I press save:
abureaux
MVP Regular Contributor
I'm not aware of anything off-hand that would cause that loss functionality (assuming you just press 'save', as you indicated). Perhaps the issue is a cross between a malformed CSV and a recently update Connect?
Could you please include the CSV and XLSX files?
Giota_Zach
Hi thanks for the reply. I 've sent a DM.
