Hello everyone,
I am working on a survey123 form and I am trying to prepopulate the images from my media folder in the image type of question (since I want those images to be easily available in survey123 feature reports) based on another question in the survey.
For example, I have a select_one_from_file question in my survey, and the user picks "56". I have 3 images in my media folder that are named as "56_1.jpeg","56_2.jpeg" and "56_3.jpeg".
I would like those pictures to be pulled into the survey from my media folder into image question with multiple appearance.
Please, let me know if this is possible, I appreciate your help!
Thank you,
Yulia
Note - I've just tried the annotation appearance and prepopulated the background image, but this is not what I need.
Would suggest setting up:
Then applying a choice filter so that the question B choices will only be based on the options selected in Question A e.g. if you pick 'America' as country for A, only American cities are shown in B
Thank you, but I don't need to just pull the names of the images, I need to pull the images.
Or do you mean to populate an image question with the images?
I don't believe this is possible.
Hi Yulia,
I am trying to do something similar. Did you find a solution?
I'm also trying to do the same thing. There has to be some formula to calculate an image from a selected media and put it as an attachment so that it can be used in the reports created by the map series tool.
