Populate Survey 123 answers from an excel
146
10-05-2022 04:25 PM
GustavoAdolfoMartinezHincapie
Hi @IsmaelChivite !
I have a survey and I want you to know it it is possible to load an excel file and automatically populate some answers.
For example:
Every two weeks a contractor sends to me an excel with a list of workers.
The excel has around 20 names and IDs. In order to request authorization from my boss to grant access to the workers, I created a survey in survey123. However, I am wasting time filling in the names of those 20 names and IDs in my survey. I don´t want to waste time typing all the info again.
So, is it any way to load the excel in the survey and automatically fill it?
2 Solutions
LaurenceTait
Occasional Contributor II
What exactly are you trying to do? Do you just want to list all the names in a single field, or do you want to have the names as options so you can fill out the survey for each person?
There's a simple enough solution either way, but you need to explain what you are trying to achieve.
In general terms, you just need to convert the Excel sheet into a csv file and then use the select_from_file question type:
https://community.esri.com/t5/arcgis-survey123-blog/work-with-csv-data-in-arcgis-survey123/ba-p/1157...
DougBrowning
MVP Notable Contributor
LaurenceTait
Thanks!!!! this was exactly what I was looking for!!!!
DougBrowning
Thanks!!! Never used AGOL before, great opportunity to learn.
