Populate EXIFINFO from upgraded attachment table
177
12-04-2023 01:48 PM
VickyWang_COM
I hope can get some clarity or possibilities about the auto-populate EXIFINFO field to attachment table.
From the Upgrade Attachments geoprocessing tool (https://pro.arcgis.com/en/pro-app/latest/tool-reference/data-management/upgrade-attachments.htm) It describes :These fields can be used by apps such as ArcGIS Survey123 that set their values through the feature service.
The ESRI Enterprise is 10.9.1 uses ArcGIS Pro 2.9.10, field apps are : survey 123 3.18.x & field maps.
1. Upgrade attachments (attachment table has additional KEYWORDS & EXIFINFO fields)
2. Publish survey uses exists Feature Service
3. Image question (NOT multiline) from sruvey 123 will auto populate the image question name as the value in the KEYWORDS field of attachment table.
Is there anyway can auto-populate the exifinfo from image without post-processing by turn a flag in survey form ?  or use attribute rule (in man feature service or in attachment table)  ?
In survey 123 can extract exif data can use pulldata () to get the exif info:https://community.esri.com/t5/arcgis-survey123-blog/working-with-exif-image-metadata-in-survey123-fo.... Would like to have other way to set parameter in the field of esri::bind::parameters or any others in the survey form that can auto populate each image exifinfo to the attachment table ?
Hope can avoid saving the attachment 's information to the main survey feature service and post processing . Hope attachment related info keep in attachment table.
Many Thanks
