Hi, everybody In survey connect , Is it possible to obtain and save the name of the day that has been obtained from a date type DateTime ?
thanks in advanced
Hi @PamelaLandy,
The way I'd tackle this is using the format-date-time function which allow you to convert date objects into strings. There's more info in the Dates and Time in Survey123 - Esri Community blog post, but I've taken the table below from that post and modified it to return just the three letter short text day (Sun, Mon, ...).
type | name | label | calculation |
dateTime | wsdatetime | Sample Date/Time | |
calculate | wstime | Time | format-date(${wsdatetime},'%a') |
Hi @PamelaLandy,
