Limit number of times a single select option can be submitted using pulldata
79
a month ago
leahmaps
Occasional Contributor II
Hi!
I am wondering if there is a way to use the pulldata function against the feature layer it creates in survey123.
What I am interested in doing is creating a single select question with 3 options (A, B, and C), but limit the amount of times each can be picked. For example, I only want option A to be submitted to 10 times, B 15, and C unlimited.
Would there be a way to use pulldata to either add a note that the option is no longer available, or remove it from the single select options?
Thanks!
abureaux
MVP Regular Contributor
Have a look at pulldata(@layer): Survey123 Tricks of the Trade: pulldata("@layer")
