Inbox query expression, reduce 5 surveys to a single survey
322
10-05-2022 02:21 PM
PaulGarcia_scruzGIS
Hi! I have 5 facility inspection surveys that use a feature layer in AGOL. Each survey uses an Inbox expression in each survey to filter out points based on 2 attributes in the data (inspection area and inspection status). Is it possible to take user input for the inspection area they want to survey and populate the survey with only points for that area? End goal is to get to only managing a single survey, not 5. Thanks!
MichelleWilliamsERM
Occasional Contributor III
You might want polygons in your inbox (with points for the related table). If this sounds like what you want, here's a video on how to do that. I also found out just recently, and it's a game-changer.
Have a spatial day.
(1) Post | Feed | LinkedIn
PaulGarcia_scruzGIS
Hi Michelle, thanks for the video link. I'm not sure this quite gets me to where I want to take my survey but it does give me some additional ideas for the next version of my survey. Cheers!
MichelleWilliamsERM
Do you have time for a call tonight at about 5 pm PST? I'd like to help if I can.
PaulGarcia_scruzGIS
Wow, I'd love to get your further insight. I am available at 5pm PST
