How to pull an address or nearest address point from a geopoint?
276
11-29-2023 11:38 AM
NickAddison
I'm using Survey123 to collect new asset data. Once a geopoint is dropped I'd like for it to pull the site address.
I found some older threads discussing this, but there was no solution implemented at the time; any solutions yet?
Tags (3)
ChristopherCounsell
MVP Regular Contributor
NickAddison
@ChristopherCounsell Thanks!
I notice that some of the points have a wide range in address numbers (sometimes a range of 500+). Is there any way to tighten that range up? Maybe pull the address number from the nearest address point? I saw discussion of this on very old threads, but didn't see where such a function was ever implemented.
NickAddison
Think I found a solution. Looks like reversegeocode.address.Address forces it to select a single address number as opposed to the range of address numbers that Match_addr, LongLabel, and ShortLabel allow.
Thanks for the help!
