Grid Theme in Survey123 Web App
114
3 weeks ago
JaredPilbeam2
MVP Regular Contributor
Note:
The theme-grid appearance value is not supported by the Survey123 web app.
I found this out the hard way after putting together a fairly large survey with Survey123 Connect. It looked perfectly fine in Connect. But, when I published to the web the theme-grid wasn't supported and the survey didn't look so pretty. I guess it's meant for a mobile device. Is there a way I can do a grid that works with the web app? I'm currently researching Pages to see whether it supports a grid theme.
Suggestions would be much appreciated.
Philip-Wilson
Esri Frequent Contributor
Hi @JaredPilbeam2,
As per documentation here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm#ESRI_SECTION1_8BFD...
And this blog post: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-groups-grids-and/b...
And you pointed out above, the theme-grid appearance value is currently not supported by the Survey123 web app.
The web app does support groups and pages, which helps organise your survey questions and display them in a neater layout, so if you like you can style your survey using these configurations, just not theme-grid appearance, it will be ignored.
Regards,
Phil.
Philip-Wilson
Hi @JaredPilbeam2,
Regards,
Phil.
JaredPilbeam2
Thanks Phil,
Ok, thanks for the links. Those are the ones I've been referencing all along. At least I'm not missing anything. I went ahead with the pages layout.
