File ownership transfer in ArcGIS online; Survey123 Connect xls missing
80
08-11-2022 08:57 AM
JenMcRuer
I am having a similar issue.
I have just moved items from a colleague's ArcGIS Online content folder to my own.  I kept all files in the same folders.
One moved file/folder is an active survey designed in Survey123 Connect. When I open this survey's files in Connect, I no longer have an xls form attached. AND the main survey icon is prompting me to refresh - but warns me "do I really want to download and overwrite?"  - I'm worried about losing data and the survey content itself.
I have checked the folderID in My Survey Designs> iteminfo file on my computer, and it matches the folder ID enclosing the survey content in ArcGIS online.
I also no longer see the xls in My Survey Designs survey folder on my computer.  Can I just upload the xls form into this folder again?  And if so, what happens when I download and overwrite in Connect to refresh?
Lastly, I am using a new MacBook Air and understand that services will no longer be updated for Connect. Could this be part of the issue?
Thank you
JenMcRuer
Hoping to receive some insight on the above, or help in where to redirect this question.
Thank you
