Existing images in S123 not showing up
152
06-14-2024 09:51 AM
kapalczynski
I am really perplexed here...
I have Feature Classes in Oracle DB
I created a S123 form in S123 Connect and updated the submission URL to point to this Service.
I can create a new record and add images etc..
But if I open the S123 form and load an existing Feature (w attachments) the data shows up but NOT the images
Any thoughts?
kapalczynski
Fixed with Running "Upgrade Attachments" on the Feature Class in SDE,
which required me to publish this with Pro not ArcMap
which then required me to update the Submission URL in S123 and republish all my forms
which required me to update all my WebMaps referencing the new Services
total pain in the ..... gotta love the efficiency... and all the documentation regarding this issue put forth by ESRI
kapalczynski
The crazy thing is the images appear in my form in my DEV environment...
I copied the data from DEV, I copied the Form from DEV.. everything should be the same...
I can see the images in ArcMap in both environments... why do they show up in one form and not the other. ugggg
kapalczynski
