Error with "select one questions" made in Connect publishing in AGOL
121
12-08-2021 05:44 AM
Direción_Metropolitana_deDesar
Hi everyone, Im experiencing some errors when I publish my survey made in Connect V3.13.249 in AGOL, there are some errors because in the simulator desktop APP everything is good, but When I publish the survey the select one questions dont work. I dont know what is wrong because there are not any message of error and I cannot find what is wrong.
I attached the survey if someone could help me
Also this is the link of the survey published
https://survey123.arcgis.com/share/6efdeb0eef224fb097b5f7b0b0c36cb5?hide=submit , here you can see "Select one questions" dont work
Thank You
DougBrowning
MVP Frequent Contributor
My guess is it is your lists.
You have a new line here - see the height of the cell
The quotes here may cause a problem
You have a lot of / in there but they seem to work.
Hope one of those is it.
I tried removing quotes and spaces and still not working
