Error when generating a Report. (An error occurred when rendering by the report engine.....)
254
a month ago
PanGIS
Hello!
Out of the blue,
on a Survey that has been working for months, this error occurs when generating a report.
The submission is associated with a Make.com scenario that suddenly stopped. 
Text of the error: An error occurred when rendering by the report engine. Failed to print map for ${Hidden_point}. EDSK1: A temporary issue occurred. Please try again later.
It is not Make.com related though, because I do not manage to print either the Sample or the proper Report from the Survey123 site, also tried to print with the single report template and nothing works.
Any clue?
Thanks!
JamesTedrick
Esri Esteemed Contributor
To confirm, there was an issue with the feature report system due to an infrastructure upgrade that occurred last night.  That upgrade has been rolled back.
abureaux
MVP Regular Contributor
Hello!
I have a thread about this already. Issue is on Esri's end.
PanGIS
My bad, I saw it after I posted.
JamesTedrick
