default value
360
09-17-2021 10:23 AM
OussamaMerhi
New Contributor II
Is there any way to change the default value for a numeric field from null to zero within an existing hosted feature service?
IsmaelChivite
Esri Notable Contributor
Yes. In Survey123 Connect: use the default XLSForm column. In Survey123 web designer: Select your question in the preview and set the default property in the right panel. In ArcGIS.com: You can set the default value when you create the field but not later).
