Connecting Integromat to an ArcGIS Enterprise instance - Error [-1]
699
10-26-2021 04:11 AM
refandreoliveira
Hi all,
I've been using integromat with AGOL with no problem.
Now Im trying to connect with a ArcGIS enterprise instance, but with no success. Ive been following this guide: https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-integromat/ba-p/89...
I make the connection successfully and integromat finds all the surveys but when I press "save" I get the following error:
Any ideas where the error might be? Any help is appreciated!
ZacharySutherby
Hello @refandreoliveira
Is your ArcGIS Enterprise organization accessible over the internet? Meaning if you were to send me the URL for your Portal I wouldn't need a VPN or anything to access it. Your ArcGIS Enterprise organization will need to be accessible over the internet so that Integromat can communicate with your org.
Thank you,
Zach
refandreoliveira
Hello @ZacharySutherby ,
Yes, I can access enterprise in any device without a VPN.
Some time ago I tried to connect integromat to enterprise survey and was successful. But at the time I was just doing some testing. Now im trying again with no success. This to say that I think it should be possible since there were no modification in our enterprise configuration.
