Collect unspecified numbers of geopoints in one survey
92
05-20-2022 05:50 AM
Boyang_Wang
Occasional Contributor II
I am creating a survey for the public to comment on our park facilities. I would like them to point out as many issues as possible on the map. My understanding in Survey123 is that it can be configured to collect multiple points in one survey using Repeats or pulldata(‘@geopoint’) function, but they seem to require to pre-determine the number of points that will be collected in one survey. Is there a way to collect multiple points without specifying how many points will be collected in one survey?
Thanks!
DataOfficer
You don't need to specify the number of repeats (or records). By default, when a repeat is set up it is not restricted by number.
DataOfficer
Boyang_Wang
I just tried to use Repeats without specifying repeat_count in the XLS and it did work. Thanks!
