Can https://survey123.arcgis.com/ be used with forms in a different Org?
295
06-30-2022 03:10 PM
DougBrowning
MVP Esteemed Contributor
We have two different Orgs - one outside the firewall and one inside.  When inside we use our inside accounts but then I cannot find a way to see the forms I have in the outside org.  All searches seem to be limited to just the Org I am in.   They are all shared with the other account.
All the apps and such can handle this so is there a way in 123 website?
thanks
jcarlson
Are you using the ?portalUrl=<your-portal> URL parameter? For instance, I get my org's surveys at:
https://survey123.arcgis.com/surveys?portalUrl=https://maps.co.kendall.il.us/portal
- Josh Carlson
Kendall County GIS
DougBrowning
This does not help.  I log in to one AGOL Organization but I want to see forms in a different Organization that are shred to me.  All AGOL not using Portal at all.  It will only show me forms in my own Org even though I am in groups that can access them.  When I download forms to my tablet this all works fine but it seems like the 123 website was not designed to handle other orgs.
Still stuck.  thanks
jcarlson
Have you tried using a collaboration to share the content across, rather than just a group?
- Josh Carlson
Kendall County GIS
DougBrowning
Some are collab groups.  The website says within my organization specifically so it seems to block them.
