Calculations in nested repeats not updating.
195
05-16-2024 01:32 PM
JoelRogers
New Contributor II
I have an inspection form with repeats within other repeats. The main repeat in a survey contains information about locations inspected during one day. The nested repeat records multiple sites within one location. I have a calculation that sums up numbers from a value (gallons) for each site for each location, and a main calculation that sums up all the gallons for each location.
typenamelabelcalculation
begin repeattrip_recordTrip Record
integerTrip_NumberTrip Number
textLoading_ZoneLoading Zone
begin repeatTreatment_sitesTreatment Sites for trip: ${Trip_Number}
select_one waterbodiesRivers_filterWaterbody Filter
select_one sitessiteSite Name
integerGallonsGallons
end repeat
integerTotal_gallonsTrip gallons sum(${Gallons})
end repeat
integerall_trip_gallonsTotal Gallonssum(${Total_gallons})
When users were filling out the survey recently, they noticed that moving back and forth between repeats to make corrections locked the calculations and the totaled sums could no longer be updated. You can change the value in the Gallons field for any of the nested repeats, but it no longer updated the calculations below. Is this new behavior?
I am using Survey123 version 3.19.121
abureaux
MVP Regular Contributor
abureaux
Have you tried calculationMode=always?
JoelRogers
New Contributor II
This was the solution. Thanks.
