Calculate field not updating after re open from draft
171
05-22-2022 02:30 PM
JaneRobbins
Survey with multiple calculate fields in the form of coalesce(${no_algae_1},0) + coalesce(${film_1},0) + coalesce(${sludge_1},0) + coalesce(${cyanobacteria_1},0) + coalesce(${didymo_1},0)+ coalesce(${other_mats_1},0) + coalesce(${green_filaments_1},0) + coalesce(${other_filaments_1},0) +coalesce( ${other_1},0).
All works ok  until the form is saved as draft and then re opened. The calculate fields then no longer update/calculate as changes are made to the associated fields.
I have a work around in that on my form I am able to hide and then redisplay all the fields. When re displayed all the fields have been emptied. As I then fill them in again the calculate field does work.
All fields are integers.
Seen on version 3.14.255, but also then demonstrated on 3.14.242.
JenniferAcunto
Have you tried setting the calculation mode to always?
The calculationMode parameter entered in the bind::esri:parameters column controls when calculations in questions are calculated, for example, calculationMode=manual. There are three supported values:
  • auto—Calculate when the question is empty or has not been previously modified by the user. If no value is provided, this is the default calculation behavior.
  • manual—The question will only calculate when clicking the Calculate button next to the question.
  • always—Calculate when any value referenced in the calculation expression changes. This includes dynamically changing functions, such as now().
Help Documentation
JenniferAcunto
Help Documentation
JaneRobbins
This did fix the issue.
But I find the behaviour inconsistent from the documentation:
# Integer values continue calculating until we save to draft and re open
# Decimal values continue calculating whether in original form or a re opened draft.
But date and time only calculate once which is very good - definitely what we need.
I applied the fix to integer and decimal calculations just in case anther application update modifies the behaviour to remove the inconsistencies.
