It would be really helpful to facilitate a workflow where once a survey has been completed, it can be reassigned as a Re-Inspection with the initial data captured pre-loaded rather than as a new survey. e.g. we use a Building inspection survey which is very lengthy. Inspectors need to reopen the Initial Inspection for Re-Inspection purposes so that they don't have to go through and re-fill the entire form again. The Inspectors only want to reinspect the non-compliances.
Hi. Can you check https://community.esri.com/ideas/13879 to see if this will help you?
