I have surveys that can have up to 150 repeats for a group of questions. To access the 35th record for this repeated group, a user now has to click the ">" 35 times. Can you add a box that allows a user to type in a number and jump to a particular repeat record?
I posted another solution idea here.
One thing that kinda helps is if you long press it will go all the way to the front or back.
