Add validation by page option to Survey123
1214
11-20-2019 08:13 AM
Status: Open
DougBrowning
MVP Frequent Contributor
I would like the option to have the survey validate fields by page.  This way a user can not get to page 2 until page 1 is correct.
My issue is that a user will skip the line number of page 1 (even though it is required).  Then on page 2 they fill out repeats that inherit the line number from page 1.  When they skip on page 1 all my line numbers in the repeat are blank.  When submitting the user then adds a line number, which makes the repeats orphaned.
Most form programs will not let you go on to page 2 if page 1 is not valid.  I cannot just hide the rest of the form due to the size causing memory issues.
thanks!
5 Comments
ChandlerWhite
Would like to add my support for this idea -- would greatly assist in preventing users from having to backtrack when a constraint error is raised upon attempting to submit a survey.
DougBrowning
As an update I am now using emojis for instant feedback.  Does not stop them but it helps a lot.
See my how to here
https://community.esri.com/t5/arcgis-survey123-documents/how-to-simulate-instant-data-checking-using...
Hope that helps someone
AndrewPadilla
I too would like to add my support for this idea. It would greatly increase the efficiency of our 10+ page surveys.
EvanR
Not sure why this hasn't gotten any traction with the developers - "hard" constraints are pretty useless to me if they don't appear until I'm trying to submit. The workarounds are fine but real-time constraints would be better.
ChandlerWhite
I would also request that if this feature were to be implemented that this validation method be made consistent across all methods of accessing a survey form -- whether that's through the Survey123 mobile app or through a desktop or mobile web browser. I found that configuration of constraints was rather tricky to implement when creating a rather long survey form to ensure consistent behavior across all platforms.
