Zoom Function/Map Choreography
241
03-09-2024 08:44 PM
Labels (2)
NathanNguyen
I can't get the zoom function to work (the one which allows for choreography) when I am transitioning from one sidecar map section to the next one. Instead, I can only choose to use the "fade" or "slow fade" transition between the two sidecar sections. Is there something else that I need to do to choreograph my map?
JamiDennis
There is no "choreography" transition - using fade or slow fade creates the choreograph effect. The trick is duplicating your map then setting the second step to the location you want to "dance" to - check out this article: https://www.esri.com/arcgis-blog/products/arcgis-storymaps/mapping/choreograph-your-maps-with-arcgis...
JamiDennis
